I get this error when trying to create a new user, what could be the problem?
/Alex
/Alex
We’ll need a bit more info to go by in order to help:
You can try registering online at Speckle. I will try and test the plugins asap too. Thanks!
Yay, i can reproduce it - in Rhino too. Something got borked. Flagged it here as critical.
In the meantime, do fall back to the previous version which you can get from here: Release Speckle-v1.2.7.113 · speckleworks/SpeckleInstaller · GitHub
Previous release downgraded to pre-release so it doesn’t spread more via auto-updates.
To give more information, I also had the problem in both Dynamo and GH.
Both using the default server.
I couldn’t log in with my old account nor create a new one, similar errors.
Heya @alelun, it’s fixed now in the latest release. It should be pushed out via the automatic updater when you will restart your computer…
Thanks for reporting!
