Failed Object Conversion on Rhino.Compute/Hops Environment
Hey guys,
I am having an issue while trying to use Hops/Rhino.Compute to receive data from Speckle.
The synchronous receiver works gracefully, and I am able to receive text, but something bad happens when I try to get geometry from my SpeckleObject.
Here is my sender.
And my hops/rhino.compute receiver.
Also, I have tried using the SpeckleToNative component inside the receiver definition and I get a similar error.
Any ideas of what might be causing it?
Oh, files:
receiver.gh (7.5 KB)
sender.gh (5.5 KB)
Hey @vwb welcome to our forum!
Does the receive operation work outside the Hops/Rhino.Compute context? If so, @Stam is the best one to help since he’s the author of the sync nodes!
Hey Matteo, everything works as a charm outside the hops/compute context.
Doesn’t feel like the problem is with the sync nodes though. For example: inside the hops context, if I use a sync-receiver, get my message from the SpeckleObject and use a sync-sender to commit, it works.
See this example:
And it works:
The exception happens when I attemp to get Rhino.Geometry from my SpeckleObject.
Back at the trenches. I figured out the ToNative/ToSpeckle and some of the Speckle components are working asynchronously, which in my experience is hardly digested by Rhino.Compute.
So I went there to write my little C# components to make conversions.
private void RunScript(object B, ref object D, ref object tol)
    // Grab kit and converter.
    var kit = Speckle.Core.Kits.KitManager.GetDefaultKit();
    var converter = kit.LoadConverter(Speckle.Core.Kits.Applications.Rhino);
    // Provide context document to my converter.
    var doc = RhinoDoc.CreateHeadless(null);
    converter.SetContextDocument(doc);
    if (converter.CanConvertToNative(B as Speckle.Core.Models.Base))
      D = converter.ConvertToNative(B as Speckle.Core.Models.Base);
      _converted = true;
bool _converted;
public override void AfterRunScript()
    if (!_converted)
      Component.Params.Output[0].ClearData();
So far so good. I was able to convert Points, Polylines, Meshes. But when I tried a Brep… :collision: Oops…
An exception occurred while processing request
System.NullReferenceException: Object reference not set to an instance of an object.
at Objects.Converter.RhinoGh.ConverterRhinoGh.BrepToNative(Brep brep)
at Objects.Converter.RhinoGh.ConverterRhinoGh.ConvertToNative(Base object)
at Script_Instance.RunScript(Object B, Object& D, Object& tol) in c:\Users\Victor\AppData\Local\Temp\z5oimfvg.0.cs:line 68
So I went on this method on the source and found this line:
 public RH.Brep BrepToNative(Brep brep)
       var tol = RhinoDoc.ActiveDoc.ModelAbsoluteTolerance;
RhinoDoc.ActiveDoc is null on the Rhino.Compute/Hops context. I was expecting the Converter to use the doc I passed on converter.SetContextDocument(doc).
Does it make any sense?
conversion-test.gh (9.6 KB)
Hey @vwb ,
Yes it makes sense! Clearly an oversight from our side, I’m afraid there might be other conversions that need fixing.
I’ve reported it here: Rhino/GH converter should use the ContextDocument and not the ActiveDoc · Issue #745 · specklesystems/speckle-sharp · GitHub
Feel free to make a PR, otherwise we’ll tackle it in the next sprint, and sorry for the slow reply!
Thanks for the help @teocomi :love_you_gesture:.
I opened the PR here: Rhino/GH Converter should use ContextDocument first, then fallback to ActiveDoc #749
Hope it helps!
