When I pushing my revit model to speckle, the data field(Record) in the query ,does not contain any other columns/data. how can I get them like room area, room name, x,y,z etc… values from the revit.
Thank you,
Regards,
Raju Ch
Thank you,
Regards,
Raju Ch
Hey @Raju_CH ,
We’ve made tutorials on interacting with Revit data in Power BI. One of the videos focuses on Revit Rooms. Take a look and let me know if it helps👇:
Full Power BI playlist here👇:
https://www.youtube.com/playlist?list=PLlI5Dyt2HaEsZHG2WJ75WIM0Brx6VHT2S
Also, don’t forget to register for the Community Standup if you want to learn more about this workflow and ask questions:
https://forms.gle/xp1zscSDeTJ1ED127
Hey @gokermu ,
Thank you for the video and its working now at my side. thanks a lot
Hi again @gokermu ,
When I used the tool tip for the number, it is not showing when I selected the room.
Please have look into above pic
Can you please share the power bi file or the project url with me? If its a private project, you can send a dm.
Hi @gokermu ,
It is working fine now, actually It is taking much to time show the tool tip display in power bi.
Thank you,
Regards,
Raju Ch.
I don’t think it should be happening. If the issue continues, please let us know so we can investigate it.
Hey @Raju_CH ,
Can you make sure Stream URL
, Commit Object ID
and Object ID
inputs are connected for the 3D Viewer Visual? You can take a look at this video too if you want to.
Okay
Thank you @gokermu
