Good morning,
is it possible to send attributes with blocks to Speckle?
I need to get them back in Dynamo
Good morning,
Hey Daniel,
Where are you publishing from?
If you can share more about the workflow, that’s also always useful!
Hi @DanielHurtubise , do you mean publishing extension dictionary information with your Civil3D objects?
If you could take a quick screenshot of the attributes you’re looking to send to Speckle, I can make a fix for you.
Morning guys,
i’m publishing from Civil 3D but actually only want to send blocks with attributes (kindda like AutoCAD).
Those blocks are catenaries actually
Hey @DanielHurtubise , following up on this - I have some bandwidth now to add extension dictionary support for Autocad/Civil3D (shouldn’t take long), but this would only be for the Next-Gen connector (which we don’t have a dynamo version for currently).
If you can send me a simple dwg of that object you screenshotted, I can test a bit and see if properties sent on it would still be retrievable with our legacy Dynamo connector!
