I need some help, I have been trying to test out the updating Revit parameters process via excel to update the comments parameter but it doesn’t seem to be work for me. I have had a look on the community channel but haven’t come across a solution that will made it work.
I have provided some screenshot following the process. I tried to follow the steps in excel docs but didn’t have much success. Hopefully someone can see where I might have gone wrong along the way and can provide some feedback.
Could you check the Speckle objects on the server that that are being send from Excel, do they miss an id property? This appears to be the issue that I am facing. There should be an id property, but it isn’t there.
Thanks for the report @Aaron_Atkinson (and patience), I finally managed to look into this and patched the issue.
Now objects are hashed correctly, and after a quick test, I can see the Revit elements are updating again
