Excel connector throwing "Add-In Error"
Hey guys
I am having some issues on using the Excel connector with my company server. We are getting this “Add-in Error” while trying to add the account. Was wondering what I might be missing here?
Just so you know, it works with the https://speckle.xyz server normally.
The same on our end. We don’t actually need it right now, but wanted to double check if we have the same issue as @vwb … we also have our own deployment
It’s an actual limitation on how excel plugins can work - we pretty much need to white list server urls on our end to allow auth redirects back to the plugin. Not sure what an easy workaround would be - ping @teocomi as if I remember correctly he screamed at a text editor for a while about this…
@vwb @AlexHofbeck
Unfortunately what @dimitrie says is correct - every redirect URL needs to be explicitly added to the store manifest…
If you can share your deployment URLs via PM I can try add them in!
