ETABs sending analysis results
I have a request from a user who would like to send analysis results along with model data up to Speckle.
Obvious benefits of that would be being able to build a custom viewer / dashboard that let us review a range of results in the web. According to the docs (How to use Speckle for ETABS - Speckle Docs) the connector currenty only supports models.
Hey @chris.welch,
Thanks for relaying the feature request! As of v3.8.1 we have analysis results extraction with the ETABS connector.
The results can be seen in dev mode, under the root. This enables custom viewer, dashboarding, consuming through the APIs etc. etc. Note that the analysis results are not intended to be used with viewer functionality (e.g. filtering) nor will they appear as properties under objects. This has been done for numerous reasons and we will be happy to discuss further with the user(s). We would also love to hear about the intended workflows with the analysis results extraction (cc @dogukan ).
Also, thanks for the prompt on the docs, we will update accordingly.
Cheers,
Björn
Awesome! I’ll pass that on
