I’m modeling my 33 story residence building in ETabs, it is a dual system building on soil class E. When I analysis it, 6/5 Beam Column Ratio are showing N/A only. What went wrong? All column and beam are concrete frame design.
Hi @Maung_Kyaw,
I believe this is a ETABS-specific issue and unrelated to the Speckle for ETABS Connector? In which case, you should contact CSi Support.
Regards,
Björn
