Error when trying to connect to Stream from PowerBi
Hi all,
im trying to connect my Speckle Stream to PowerBi.
When i click get data in PowerBi, and select “Speckle get stream by url (beta)”, and put in my url, it asks me to login.
When i click login it gives me an error “a value cannot be null. Parametername: uriString”
and then its just loading, but not connecting to speckle.
What am i doing wrong?
Hey @Svendsen ,
I’m sorry to hear that you’re having trouble receiving your data in Power BI. Can you please help me understand the situation better by answering a few questions?
  • Are you trying to connect from a work computer or your personal device? If it’s a work computer, maybe try connecting from your personal device to see if that makes a difference.
  • What version of Power BI are you currently using? If you’re not using the latest version, it’s worth updating to see if that resolves the issue.
  • Have you tried switching to English to see if that helps?
If none of the above works, you can try authenticating with a Personal Token. Don’t worry, it’s not as complicated as it sounds! Here is a guide that will walk you through the process step by step:
Hi Mucahit,
Thx for the reply. It help when using the personal token :slight_smile:
