I’m using the Python SDK in a Jupyter Notebook, and a script that previously ran fine is failing this morning due to what looks like a certificate error at the Speckle end of things. Is anyone else getting this? Are the Speckle team aware of this?
Error sending metrics request: HTTPSConnectionPool(host='analytics.speckle.systems', port=443): Max retries exceeded with url: /track?ip=1 (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1129)')))
C:\ProgramData\Anaconda3\lib\site-packages\specklepy\objects\units.py:33: SpeckleWarning: Invalid units: expected type str but received <class 'NoneType'> (None). Skipping - no units will be set.
warn(
