…which is unfortunately too small/not able to expand the window to even see which DLL failed to load. Is there a log file somewhere in Rhino that I can retrieve this information?
Ok, solved. It looks like I downloaded the x64 version of the plug-in but was attempting to load it into a 32bit Rhino. Of course. I doubt anyone uses that version of Rhino, neither do I. It was a mistake.
It’s actually more widely used than you think, but i suspect it’s mostly people just using the first shortcut they encounter! There were quite a few problems with this before…
could you send me a screenshot of your rhino loading splash screen? The important part is the version number; we might have upgraded to a newer sdk release and, consequently, caused this problem - but not entirely sure. We’re using 6.1.18.
is by any chance the .rhp blocked, or any of the more obvious dlls in there? would ideally like to see the stack trace of this - does rhino provide more info besides the rather cryptic warning you showed us earlier?
Okay, some extra questions for you @francesco_perego! With @Alessio_Lombardi we’ve encountered this, and it was solved by the following:
take care that there’s no residual SpeckleCore.dlls left around anywhere. This should not be an issue if you’ve used the installer, but you never know - especially if you built it before yourself.
Something might have went wrong, and some dependencies are not in the right place. Can you check in %localappdata if you have a SpeckleKits folder, and if there’s anything in it?
This means that it didn’t get installed in its traditional place, which, on my machine is at C:\Users\dimitrie.stefanescu\AppData\Local\SpeckleKits. Can you try running the latest installer again? Thereafter, you should see a SpeckleKits folder in your local app data folder, which should contain the required dlls.
Let me know if this helps you out. Otherwise, if there’s no specklekits folder there must a problem with the installer and your specific setup; in which case I’ll have to look deeper.
