Hi Speckle team,
I am running in the similar issue, to that solved here:
However if I apply your medicine I get the following message:
Any suggestion?
Miroljub
Hi Speckle team,
Any suggestion?
Miroljub
Hey @Miroljub_Anastasov,
Sorry to hear that! Just so that I have the full picture, what medicine from the previous solution did you apply?
Did you try:
For me to help you a bit further, could you also tell me:
We will get this sorted ![]()
Hi @bjoern,
Thank you for getting back. Sorry for the sparse description previously, let me try to provide a big picture.
The steps I have taken: already removed and installed again the speckle ETABS connector. After that I have tried to manually add plugin as described in a post from speckle team, which leads to the error message.
Let me know if you need more information.
Looking forward for your support.
Miroljub Anastasov
No worries @Miroljub_Anastasov - thanks for the infos. Okay wow, you’ve got the brand spanking new version of ETABS
. Currently the ETABS Connector support only goes up to v21.
I will need to try this out on my end and I’ll get back to you! ![]()
Cheers,
Björn
@bjoern, we’ve had a business-wide upgrade to ETABS 22, and folks are crying out for an ETABS plugin update - if it’s not ready for the general public, is there a test branch I can build the plugin from that I can distribute to those who are keen?
Hey @chris.welch.
Nothing yet for testing, but we’re working on ETABS 22 support as part of Next-Gen Connectors. So, knowing this is great, thanks!
I’ll keep you posted
cc: @dogukan
Thanks @bjoern, appreciate it - let me know if you need testers or anything, let me know
