Hii
i am trying to setup the speckle server locally by referring through the documentation and i’m encountring following error . please do suggest me what to do.
ERROR: Error executing task {“component”:“fileimport-service”}
➤ YN0000: [@speckle/fileimport-service]: err: {
➤ YN0000: [@speckle/fileimport-service]: “type”: “DatabaseError”,
➤ YN0000: [@speckle/fileimport-service]: “message”: “password authentication failed for user "speckle"”,
➤ YN0000: [@speckle/fileimport-service]: “stack”:
➤ YN0000: [@speckle/fileimport-service]: error: password authentication failed for user “speckle”
➤ YN0000: [@speckle/fileimport-service]: at Parser.parseErrorMessage (C:\Users\DELL\Desktop\3d\speckle-server\node_modules\pg-protocol\dist\parser.js:287:98)
➤ YN0000: [@speckle/fileimport-service]: at Parser.handlePacket (C:\Users\DELL\Desktop\3d\speckle-server\node_modules\pg-protocol\dist\parser.js:126:29)
➤ YN0000: [@speckle/fileimport-service]: at Parser.parse (C:\Users\DELL\Desktop\3d\speckle-server\node_modules\pg-protocol\dist\parser.js:39:38)
➤ YN0000: [@speckle/fileimport-service]: at Socket. (C:\Users\DELL\Desktop\3d\speckle-server\node_modules\pg-protocol\dist\index.js:11:42)
➤ YN0000: [@speckle/fileimport-service]: at Socket.emit (node:events:513:28)
➤ YN0000: [@speckle/fileimport-service]: at addChunk (node:internal/streams/readable:324:12)
➤ YN0000: [@speckle/fileimport-service]: at readableAddChunk (node:internal/streams/readable:297:9)
➤ YN0000: [@speckle/fileimport-service]: at Readable.push (node:internal/streams/readable:234:10)
➤ YN0000: [@speckle/fileimport-service]: at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
➤ YN0000: [@speckle/fileimport-service]: “length”: 103,
➤ YN0000: [@speckle/fileimport-service]: “name”: “error”,
➤ YN0000: [@speckle/fileimport-service]: “severity”: “FATAL”,
➤ YN0000: [@speckle/fileimport-service]: “code”: “28P01”,
➤ YN0000: [@speckle/fileimport-service]: “file”: “auth.c”,
➤ YN0000: [@speckle/fileimport-service]: “line”: “338”,
➤ YN0000: [@speckle/fileimport-service]: “routine”: “auth_failed”
➤ YN0000: [@speckle/fileimport-service]: }
