Enable solid hatch in online viewer
Currently, when an object is a solid, there is no hatch generated when i cut it with a section plane.
Is it possible to enable this hatching? it will make much easier to understand some sections with a lot of elements aside of each other.
e.g.: i challenge you to find the walls in the image below:
Now find them in this one:
And it’s not an easy problem. @alex put in quite some investigation into this some time ago:
PS: even the forge viewer has a setting to disable them bc they can be inconsistent in some scenarios.
Yes, I think the user should have the option to disable them from time to time, so they can be off by default but turned on when needed (like we should have for shadows for instance :wink: )
I understand it is difficult so no rush, but it is something of much added value
