E-mail Verification mails are not getting
Hi Teams,
I deployed speckle-server on my VPS using docker and docker-compose by refering to this guide Speckle Deployment and which is working fine.
But the issue now I am facing is : not receiving account verification emails and also not able to reset the password.
I went through the previous topic but I did not understand it because I used docker images for the deployments and I do not know how to add the email.
Thanks in advance for the help.
Regards speckle lover,
Ramkumar
Hi Ramkumar (@Soft_Big_Bear ),
Welcome to the Speckle community. If you haven’t already, please take a moment to let the community know a little more about yourself and what you are hoping to achieve with Speckle.
To enable email, you should add the below to the speckle-server environment block, replacing the content within the quotation marks with the appropriate value for your email service.
If your organisation does not operate an email service (SMTP server), you may wish to sign-up for an online service - such as MailJet, MailChimp, or any of the many other similar services. Alternatively, if developing locally or testing you may wish to use a locally hosted SMTP server such as Maildev.
EMAIL: "true"
EMAIL_FROM: "<email address used in the 'from' header of sent emails>"
EMAIL_HOST: "<email host domain>"
EMAIL_PORT: "<port number>"
EMAIL_USERNAME: "<username of email service, if required>"
EMAIL_PASSWORD: "<password of email service, if required>"
Iain
