I have had speckle running on my machine and no issues with the nodes for Revit 2019 and dynamo. I just got Revit 2020 installed and speckle in dynamo requested for the latest to be downloaded. So I did, but now it won’t stop requesting it.
Hello @Hurkan!
That only means that you have a very ancient version of Speckle installed for Dynamo, when it was still distributed via the Dynamo Package manager.
Under the view tab in Dynamo I do not have the option to manage my Speckle account. Speckle works on everything else apart from Dynamo. I know of someone else who has the same issue as me.
@Hurkan and @daviddekoning
Can you please double check and let me know your exact Dynamo version?
Speckle for Dynamo currently supports Dynamo 2.1 and newer, it might be that you are currently using an older version?
I just tried the installer and it did work fine, so I don’t see why it shouldn’t work for you
Apologies for the mess-up, the release I linked above is carrying a bug that prevents the sender/receiver to work. I’ve unlisted it, but since you’ve already installed it, can you please install this new pre-release:
