Dynamo Stream Is Invalid
Hello.
After managing to install Dynamo connector 2.20, I tried to use it but I keep getting told the stream is invalid. I am using Dynamo version 2.16.2.
I tried following the tutorials posted but it kept giving me “stream is invalid” and not allowing me to send data.
What does your dynamo script look like?
what url are you inputting?
and are you able to send/receive to that project in other connectors?
My Dynamo script is a basic one to create points in a grid with circles created using those points as centers.
I am inputting the final result from the Dynamo script using the Speckle send block.
And I am able to send and receive the Revit project this Dynamo script is created from.
Hey @HadiAram ,
Are you able to send and receive via Dynamo? What’s the issue?
Can you share the Speckle Model URL with us? This error indicates something wrong with the URL. Are you able to view it in your browser? Is it a model URL that you own/created or are you using what’s in the tutorial?
Apologies for the late answer @gokermu but no, I am not able to send via Dynamo but I have not tried to receive it via Dynamo.
My issue is when I try to use the stream block and connect it to the send block, I am told the stream is invalid. I am currently not at my workstation so I can’t send the model until Monday, but I will do so as soon as I can.
Hello @gokermu
I am back at my workstation and here are my Dynamo model and my Speckle Model URL. I hope this helps.
https://app.speckle.systems/projects/8f966b707e
Hey @HadiAram ,
The URL you pasted is a project URL. Can you try with a Model URL instead?
Also, do you have Revit connector installed? If above suggestion doesn’t fix, can you also try with Revit connector installed?
Hey @gokermu
I do have the Revit connector installed but I will try the Model URL now that I am back at my work station.
However, if by Model URL you mean a model from Dynamo, I am unable to push any models in Speckle from Dynamo. If this is something I need to change, then I will, but I can’t get any models into Speckle from Dynamo as a result of the error above.
I am not sure why, but the stream is now working. I turned Dynamo on again and now I can push models into the project. Is this something that normally happens?
Are you still using 2.20 release?
Yes, I am still using the 2.20 release.
I tried a few things and when creating a new stream in Dynamo I get the same error of the stream being invalid, when I try using stream.get I get told I don’t have any accounts for app.speckle.systems, but the stream I created yesterday through Dynamo still works.
Update: I tried using the Legacy app and it worked immediately. Is it possible that the Dynamo connector is still working off the Legacy app first and then the new web app?
Do you have app.speckle.systems account added on Manager?
The account I have is saved as speckle.xyz it seems. I will try this now.
Update: It worked. Thank you for the help.
Edit: It seems newly created projects take time to register still, but everything else is working just fine.
That’s great to hear! Let us know if you have any other problems.
