Dynamo Revit Tutorial Upload Empty Models: No displayable objects found in object
I’m following the: Getting Started With Speckle For Dynamo (speckle/tutorials/getting-started-with-speckle-for-dyanmo) but the model that i upload to speckle server is empty.
Speckle Server: app.speckle.systems
Connector Version: 2.15.4
Revit Version: 2023 - Version 23.0.11.19 20220503_1030(x64)
Dynamo Core: 2.13.1.3887
Dynamo Revit: 2.13.1.3891
Logs: [Dynamo Revit Error](Dynamo Revit Error · GitHub]
Stream: Speckle
When we open the streams, we can see the data in the side bar, but i’m having the following message:
No displayable objects found in object.
Hi @luisfelipemileo,
I’m sorry to hear that you’re experiencing issues with the Speckle Dynamo Connector.
After having a look at your logs, I saw that you are sending only one item. Please use the second output on your code block. See the image below.
Let me know how it goes.
worked!!! Thanks!
Viewer - Symmetrical Treehouse - Speckle
