Dynamo Models Don't Show 3D Objects Or Altered Objects
Hello again,
I am having issues with getting some objects to appear in Speckle when sent from Dynamo. When I try sending 2D objects like circles, everything works fine, but 3D objects like spheres do not appear.
In addition to that, any alteration to the data makes it so the data does not appear in Speckle either. When I tried to color the circles for example, there were no circles sent to Speckle.
I am using Dynamo 2.16.2 and the Dynamo connector 2.20.
Please see here the list of supported elements: Supported Elements | Speckle Docs
What are you trying to achieve? Usually grasshopper is much better for handling geometry, and Speckle supports all element types in Rhino/GH. :slight_smile:
In general, I was trying to test a few things for later use before we got to the necessary stage, but I will keep this in mind. I will go over the list of supported elements and see if there was anything that should appear but didn’t.
Thank you for the help.
