Dynamo connector
Hello There,
I’m encountering some difficulties with the Dynamo connectors. Despite installing the latest version on my device, it doesn’t appear in Dynamo. I also attempted to install it via the Dynamo packages, but the available version there is outdated. Any suggestions on how to resolve this issue?
Thank you in Advance
Hi @Mohammed_Hamdallah! :wave: Welcome to the community.
Just to gather some more information:
  • Can you confirm the version of the Dynamo Connector - 2.19.3?
  • What version of Revit are you using?
Regards,
Björn
Thank you for your reply, Bjorn!
For Dynamo, it’s 2.19.3 (the last version)
For Revit, it’s 25.1 version
Hey @Mohammed_Hamdallah,
Revit 2025 uses Dynamo 3.0, which Speckle does not support yet.
You can use the Revit connector to send your model to Speckle, or you can use an older version of Revit/Dynamo with Speckle.
@Mohammed_Hamdallah Maybe you could try copying and pasting the installed Dynamo connector into the Dynamo 3.0 folder. I can’t promise it will work, but it’s worth trying.
