Can you please confirm the version of the connector you are installing?
Also can you send a screenshot of the Dynamo packages, of let’s say Dynamo 2021?
What do you see under “Manage Packages…”? I’m trying to understand if the plugin is copied correctly.
You should also see its folder in %appdata%\Dynamo\Dynamo Revit\2.6\packages.
Hi
After copying the folder
to
%appdata%\Dynamo\Dynamo Revit\2.3\packages
and
%appdata%\Dynamo\Dynamo Revit\2.12\packages
It is available for Revit 2020 and Revit 2022.
Why it is not available automatically?
Shall I need to update folder manually after each and every update?
Hi @Kumarravi007 I see, the problem is that Dynamo has been quite inconsistent in how they released updates and matched them to Revit versions, there seems to be no logic
I’ve updated the installer script to also target 2.3 and 2.12, so going forward you won’t need to copy/paste.
