Discuss about Improvement Geometry Objects Library
I have some problem need discuss about Library Speckle Objects:
  1. Replace some method static like CrossProduct and DotProduct for easy use API :
Current :
/// <summary>
    /// Computes the vector product (cross product) of two given vectors
    /// Cross product = { u2 * v3 - u3 * v2; u3 * v1 - u1 * v3; u1 * v2 - u2 * v1 }.
    /// </summary>
    /// <param name="u">First vector.</param>
    /// <param name="v">Second vector.</param>
    /// <returns>Vector result of the cross product.</returns>
    public static Vector CrossProduct(Vector u, Vector v)
      var x = u.y * v.z - u.z * v.y;
      var y = u.z * v.x - u.x * v.z;
      var z = u.x * v.y - u.y * v.x;
      return new Vector(x, y, z);
Can replace by :
/// <summary>
    /// </summary>
    public Vector CrossProduct(Vector v)
      var x = this.y * v.z - this.z * v.y;
      var y = this.z * v.x - this.x * v.z;
      var z = this.x * v.y - this.y * v.x;
This will be help all developer easy use API and code look beter , how you think about this ?
At the moment with API :
  void DoSomeThing()
            Point p1 = new Point(0, 0, 0);
            Point p2 = new Point(4, 0, 0);
            Vector vector = new Vector(p1);
            Vector vector2 = new Vector(p2);
            var result = Vector.DotProduct(vector,vector2);
After change :
        void DoSomeThingImprove()
            var result = p1.DotProduct(p2);
Note : This just a example for that, many method inside code is same now.
  1. Will be add libary G-Shark to use and Upgrade for this, but I see base code current is not easy to change.
If don’t have any problem, I will try pull request some hack help this :slight_smile:
