I’d like to build a barebones application that can receive data from a speckle stream in a server context. It seems like most of the Speckle.Core API operates on the assumption that it’s executing on the same machine as the SpeckleManager is installed, so it can draw on locally stored auth, account management, etc. I’ve been struggling to figure out how to get things up and running in a context without the SpeckleManager.
Eventually I’ll move to having some kind of clean auth flow, but for now ideally I should just be able to consume some minimum set of information (a user token, a server url, a stream id, or whatever) as strings, and then be able to access the stream. Are there any examples that work this way for me to start from?
The .NET SDK has been designed to be used primarily with SpeckleManager, but it’s possible to also use it without.
For example, see the code below:
using Speckle.Core.Api;
using System;
namespace SpeckleSampleApp
class Program
static void Main(string[] args)
var account = new Account();
account.token = "YOUR-PERSONAL-ACCESS-TOKEN";
account.serverInfo = new ServerInfo
url = "https://speckle.xyz/"
var stream = client.StreamGet("5dfbeb49c9").Result;
