I am trying to connect to a model getting the below error.
I have confirmed that the data source credentials are correct
Details: “Access to the resource is forbidden.”
Hey @cbmccreary ,
We’re working on PowerBi support for private projects, for now you need to set it to “Link Shareable”.
Does this also include the Speckle Power BI 3d viewer?
Indeed! Offline mode and private projects.
Are you able to use any other of our desktop connectors? This could be a network issue…
We are investigating the issue. I was running the PowerBI on a VM which may have internal policy settings stopping the traffic … I have tested in on a local machine and it does work
Thanks for help
