Hi, I’ve run into a possible issue with data structures in grasshopper while expanding my Speckle object:
Having the base object B1 with some nested speckle objects inside.
If I expand the B1 object, the output preserves the data-structure for the nested objects. ie. the bullnose is at branch {0;6;0} and handrails at branch {0;7;0}.
If I expand the Handrails object, which would result in some meshes inside (not a speckle object). then I would lose the data-structure. going from {0;7;0} to {0;0;0;0}!
Could this be in a way that the mesh output would keep the branch name {0;7;0} ?
Could you send me the file so I can better understand what’s going on there?
