Custom data info on speckle viewer
Hello guys I need help with something that should be pretty basic but I can’t find the solution anywhere.
I wanted to show on the speckle viewer customize info for the different objects.(meshes)
Instead of whats on the image above, I wanted to output my data, something like this:
Is this even possible?
Thank you very much for your help
Cheers
Edu
Hi @idu059774
You can find the web app package here and you can use it as a starting point for your own application that behave the way you’ve shown in the image. Alternatively you can use the speckle viewer in a much simpler application, like our sandbox with package source here
To answer your question, yes it’s very much possible, however you will need to develop that custom behavior yourself
Cheers
Hi Alex,
Thank you very much for your quick response.
I don’t need it to be highly customized. Is there a way to simply add a few lines of text to the properties of the speckle object from Grasshopper, so that it appears as part of the information in the Speckle viewer?
Hi @idu059774,
You need to use “Extend Speckle Object” to add your custom property and data.
Hi Nikos,
Thanks a lot for your reply. That should do it for now.
Have a nice week
Edu
