I found out why some wallsby baseline and levels were not generated. They where on the wrong level.
It did not know about the report tab. (nice feature)
It gives the following warning:
Hey @Erik_Beeren , I could replicate the issues when receiving walls by face in Revit 2022. Funny enough, it works for 2023 and 2024 version and as a temporary workaround you could try Revit 2023, 2024 while we make this work.
Wall openings are problematic in all Revit versions though so no workarounds here. We are investigating and fixing…
Thank you for the feedback.
I installed Revit 2024 and the “walls by face” are being generated in Revit.
Tank you for sorting this out.
However these walls do not seem to be real walls any more.
I cannot modify them like the other walls generated or native Revit walls by face.
The corners are not being connected to each other.
In fact these walls behave more as direct shapes then Revit walls.
Native Revit “walls by face” can be edited. Our aim is to generate a Revit model from Grasshopper which can be modified in Revit like it was a Revit model.
Thanks for the feedback @Erik_Beeren. @Pavol is going to take another look at this, but if we can resolve the walls issue in 2023/2024, does that work for you?
