I’m struggling with a CORS issue when trying to upload a new IFC model. I have a S3 API compliant public access with cors enabled.
Speckle Server Version 2.26.5, set S3_ENDPOINT and FF_NEXT_GEN_FILE_IMPORTER_ENABLED to true. I’ve also set all S3 properties correctly.
When uploading a new model within the frontend, the S3 clients put preflight fails with code 403 telling that,
Response to preflight request doesn’t pass access control check: No ‘Access-Control-Allow-Origin’ header is present on the requested resource.
Indeed, it’s missing and I like to use CORS.
Is there any possibility to configure CORS behaviour with speckle for S3 AWS client? There is an example inside AWS documentation - aws-doc-sdk-examples/javascriptv3/example_code/s3/actions/put-bucket-cors.js at 309de24d867a2b3f01d4da8018ad8173243556af · awsdocs/aws-doc-sdk-examples · GitHub.
Does anyone have experience on this?
Cheers, Bernold.
