Hello, I couldn’t find an answer to this anywhere else. I am a Revit user. I am using Rhino with Speckle to bring a third-party model into Revit. The model was originally made in ArchiCAD but was given to us in Revit format. In Revit, everything in the model is a Direct Shape. When it is imported into Rhino, everything in the model is a Block. Is there a way to convert Blocks into Extrusions and Surfaces, so that I can assign them to the right Revit Element categories for conversion? Is there something else I’m missing to make this possible? The only other option I see is drawing over the entire model from scratch in Revit using the imported Direct Shapes there as a guide which would take a long time.
Thank you, SZ
EDIT: Obviously not a usual Rhino user, but I figured out how to explode the blocks and then assign categories. However it’s going to get messy, any tips on workflow here? Also, I’m still getting a SEND FAIL message after doing this.
