Vincent
(Vincent Cadoret)
1
Objective: Connect Speckle Manager to a local development server (http://127.0.0.1:8081/)
Issue: The browser pops up, authenticates but then Speckle Manager throws an error:
Is connecting to a dev speckle server from the speckle manager something that is supported?
teocomi
(Matteo Cominetti)
2
Hey Vincent, this is definitely supported.
Could you send the Manager logs?
Any luck authenticating directly from the Connector UI in Revit/Rhino?
Vincent
(Vincent Cadoret)
3
In the end I got it working by point it to http://localhost:3000/ which then gave me this error:
The process that was holding on to Port 29363 was the System process so I rebooted and started over and now it works
