Hey guys,
Do you know where the dimensions of the columns are stored? I can’t seem to see them in the viewer. ı have sent a simple model from ETABS, trying to recreate same model in Revit using Dynamo.
Hey guys,
Hi @gokermu !
Unfortunately we are only passing properties of columns by name if they’re a catalog section. If it’s a concrete section, the dimensions are passed by the section profile property underneath Property1D of the column.
I will work on a fix to pass properties so even if it’s a catalog section, that some dimensions get passed !
Cheers,
Reynold
Got it. Then naming convention should reflect the dimensions if I wanted to recreate those columns in Revit.
Yes if you want to pass the columns directly in Revit, you should have the same naming convention .
