Closer Look at Speckle View Modes
Hey @Community
We’ve just posted an in-depth look at how we’ve implemented outline rendering as part of the new view-modes feature that recently came out for the viewer
You can check it out here: How Speckle Generates Outlines from Geometry Data
As always we’d love to hear your feedback so please don’t hesitate to reach out with any suggestions, comments, or questions
Cheers
:+1: :+1: :+1: :+1:
(the antialiasing process seems not to retrigger after you change your projection, you need to fiddle with the camera for it to refresh)
If you’re working on your shader pipeline, here’s an interesting use case that might test the limits of what you’re up to - terrain contours! GLSL Geometry Shader Text - Rhino Developer - McNeel Forum
  • Only applicable to a subset of object types in a scene
  • Relies on object metadata for units (mm or m, RL above sea level or a known datum?)
very tempted to make this my desktop background.
I already did
