We were testing the following workflow yesterday for an upcoming project: alignment in Civil3D > receive in Revit. Model lines were nicely generated in Revit, awesome! There were two things though.
- UPDATING: after modifying the alignment in Civil3D, receiving the update in Revit didn’t worked properly. In Revit, the alignment is cut up in separate model lines so I think it’s not updating all of them. Or could there be something else causing this?
Receive 1:
Receive 2 (after update in Civil3D), as you can see a lot of duplicates and only the first model line on the bottom right has been updated:
- DYNAMO: trying to receive the alignment in Revit dynamo gave an error. Is it possible to disable deserialization in the receiver (as you can in GH)?
