Hi All,
I recently sent a stream of a pipe network containing pipes/pits in civil 3D to Revit, however it was imported very small (in “m”).
I went through all the documentation but couldn’t find anything related to required steps for sending importing data between both packages in regard to setting units.
As most know, in civil we model in meters and the majority (if not all) of the Revit community, model in “mm”.
What do I need to do to send data from civil 3D in “m” units to Revit in “mm” units?
Using Civil 3D 2024.2 and Revit project in 2022.1
Any help would be much appreciated, thanks.
