When exporting from civil 3d , pressure pipes not exported.
Speckle link project : https://app.speckle.systems/projects/e658e396c1/models/d48c5e23c2
Civil 3D attached file:
test.dwg (975.9 KB)
test.dwg (975.9 KB)
Hi @Mahmoud-Rawi ,
Thanks for sharing a sample file. I was able to reproduce your issue. They are actually exported but they do not have any geometry so they don’t show up in the viewer.
It seems it’s only possible to select a pressure pipe from the prospector. Because when I select the alignment object and publish it to Speckle, I am able to see its geometry.
I will add this to our backlog. Thanks for reporting it.
Thanks @gokermu for your reply, we are waiting very soon to solve that.
We try to export to Navisworks and then to Speckle. It works. But from Civil3D it will be shorten workflow.
P.S. @Mahmoud-Rawi is the BIM Manager of our team
Hi @Mohamed_Elmasri ,
I just pushed a fix for this that will be available from the next release of Next-Gen connectors.
Here’s a sample model from the file you attached:
Thanks for you update. Definitely I will test it once it pushed and released.
