Hi!
I am trying to represent a graph-like data structure in Python with Speckle schemas and am running into a recursion problem. I’ve gone over all the documentation I can find without much luck.
I have a pair of classes that each references each other. Defining the schema in Python works fine, using the Brep
example in the standard objects kit (Foo.update_forward_refs()
) so I am able to make and use these objects. I have set all the reference members as detachable, as in the examples (class Element(Base, speckle_type=... + "Element", detachable={"foo", "bar"}):
When it comes to serialization, however, I get RecursionError: maximum recursion depth exceeded while calling a Python object
, which suggests that the serializer goes off chasing those references.
Modifying the basic Python example also gives the same result, so it doesn’t seem to be a product of my schemas:
from specklepy.objects import Base
from specklepy.serialization.base_object_serializer import BaseObjectSerializer
detached_base = Base()
detached_base.name = "a detached base"
base_obj = Base()
base_obj.name = "my base"
base_obj["@nested"] = detached_base
# Spiderman meme -----------------------
detached_base["@reference"] = base_obj
serializer = BaseObjectSerializer()
hash, obj_dict = serializer.traverse_base(base_obj)
hash, serialized = serializer.write_json(base_obj)
deserialized = serializer.read_json(serialized)
Is there a part to the serialization that I am missing to be able to properly serialize cross-referenced objects? Apologies if it is right there, staring me in the face… Thanks!
heya @TomSvilans !
so this is part bug and part design
the design: self referential loops in core (py as well as c#) should be ignored on serialisation (see #2 in this list here).
if you want the parent to be injected into nested child elements, you’ll need to write your classes and handle this on set as the Brep
object does
I believe we settled on this because serialisation happens from inside out so the deepest nested objects get serialised first - the last object to be serialised is the root object. this means we don’t have the id of the root until the very end which means it’s not possible to nest it’s id as a reference in deeper child objects.
the bug: this should not throw an error but should instead be ignored as it is in sharp! i’ll pop in a fix for this soon hehe
Thanks @izzylys
I was wondering what the _inject...
methods were! I’ll give it a shot and see what happens.
I noticed that it serializes/“works” when I set serialize_ignore
, but then I don’t get any data back out afterwards
no prob dude! yep, serialize_ignore
does exactly that - ignores the property on serialization
(which is what should happen in this case). you should add any self referential props to be ignored when defining your classes - again the Brep
class and all it’s little bits are a prime example of this
lemme know how you get on!
Alright, it serializes… but then there is the problem with deserialization:
- I have 3 classes:
Element
, Joint
, and JointPart
Element
has a list of JointPart
objects
Joint
also has a list of JointPart
objects
JointPart
has a reference to one Element
and one Joint
each. It acts as an interface between elements and joints (hyper-edge).
- I’ve implemented
_inject_self_into_children
for Element
and Joint
and added the element
and joint
properties of JointPart
to serialize_ignore
Sending this off works, and receiving it works, but now when I crawl the returned Base
object, each JointPart
object turns up in 2 places:
- When looping through each
Element
, I get the JointPart
objects with a correct element
property (referring to the Element
) but None
for the Joint
property.
Joint
objects with a correct joint
property (referring to the Joint
) but None for the
Joint` property.
- While both
JointPart
objects share the same id
, they fail an identity assertion, which makes it tricky to extract one “true” JointPart
object from this.
I’ve attached the object schema and 2 scripts that push and pull data, in case that is helpful
Does this call for a custom deserializer or something like that? Are there any Python docs for this? Even C# docs could help
glulamb_speckle.zip (2.9 KB)
looking at the code, I think this is the expected behaviour.
EDIT: tbd i am checking something in sharp atm but maybe i am wrong and there is something we can do in py to handle this
when you’ve received the objects back, your Part
looks something like this
"id": "f9ac9962aa45c8e7a9b2e24a82536d18",
"speckle_type": "GluLamb.JointPart",
"totalChildrenCount": 0,
"name": "jp1",
"units": "m",
"applicationId": null
it has no knowledge of any Joint
s or Element
s.
what inject_self_into_children
is doing is adding a reference of the parent onto the child when requesting the children. so eg when getting the Parts
on Joint
, each Part
will have the Joint
inserted into it. however, each Part
in Joint
has no awareness of any Element
s.
same with each Part
in Element
- each Part
gets the parent Element
injected into it, but has no awareness of any Joint
s.
this is because upon deserialization, you’re creating objects from strings so even thought you conceptually have the same Part
inside Joint
and Element
they do not point to the same thing in memory so mutating the Part
in Joint
will not also mutate a Part
in Element
. this is also why they don’t ==
each other - they are not the same object in memory. i don’t know if there’s currently a way around this on the serialisation side.
I think it might be more helpful to take a step back and understand what it is you want to do and determine if this really is the optimal data structure.
maybe need some additional helper methods on your objects to construct one of these object types rather than try to rely only on serialisation to get what you want?
or maybe one of these object types doesn’t actually need to be an object and can just be a tag / property on the others?
Righto. I think to completely reconstruct the objects, I’d need to aggregate the two Part
objects together, probably by holding the “one, true” Part
in a dictionary with the ID as the key or something. Then replace the instances of the fragmented Part
objects with the true one.
You’re right, there probably is a better way to structure the data for serialization / transport. But in that respect this is exactly an attempt to see where the tricky stuff is for serializing such a data structure… In native code it is a very convenient structure: basically just bidirectional references between joints and elements, so it stays quite flexible… at the cost of the difficulty for serialization.
Another way might be to construct IDs for each object independently of their children - or otherwise give each object a unique tag (or a Reference
object?) - serialize them independently, then deserialize them independently, and make the connections / pointers to the actual objects in a second pass.
I’ll give it a crack
Thanks for the detailed feedback!
ok, SO! update for ya - I was wrong and we actually did make a change in Core a few months ago regarding holding deserialized objects in memory so that two disconnected objs with the same ID would still return the same instance. this change was not propagated to specklepy (oops!) and I will add it to my to dos - however it will not be the quickest fix as I’ll need to rework a couple other things - namely Brep deseiralisation (as some of the brep components are likely to have the same id
while belonging to different breps which can cause some nasty bugs as these carry references to their parent breps!)
regarding what you can do right at the mo, my first instinct (as it seems the easiest solution to me lol) would be to add a unique tag eg maybe when setting a joint
on a part
, also add the name
of the joint in the setter to a serializable prop. then you could eg have a helper method that goes through a list of elements and constructs and returns a list of joint
s by name each containing its list of part
s.
btw I think it would help to add __repr__
methods to the classes to help you better visualise what’s inside them. i’ve made some edits to the classes and the create
method that will let you see the properties just by printing (zip attached).
also remember that if you don’t have an __init__
method, you shouldn’t set class attributes with mutable defaults (eg empty lists) because you’ll run the risk of mutating a class attribute rather than the intended instance attribute (see here). either only use None
as the default and initialise it in the __init__
method or always re-set the val on a property setter
glulamb_speckle_izzy.zip (29.7 KB)
Thanks, Izzy! That sounds great, and obviously no rush from my side on the specklepy changes, it’s not mission-critical at all
The tagging idea sounds like a good method, and I was thinking about something like this or self-generated IDs to tell what is what afterwards anyway. I’ll give it a whirl, and perhaps also see if I can implement these schemas in .NET and see if the serialization there is any different.
I was wondering about the __repr__
methods… I implemented them on a couple of the classes, but was also wondering if they in any way affect the hashing of an object? Or is it purely for display purposes?
I did run into the problem with modifying a class list instead of an instance
It led to a lot of confusion, as different elements’ joints
properties were showing as equal and adding something to one list, added it to all the lists (now obviously since it was the same list
sure thing - let me know how it goes! and i’ll update ya when I am able to implement the serialization update in specklepy! and yes, as of the update to BaseObjectSerializerV2
in C#, you will get the expected behaviour you’re looking for if you implement this in .NET
__repr__
is a special python “dunder” method that any class can implement to overwrite the string representation of a class (eg what you see what you print
the object). any class (speckle or not!) can implement this and it won’t affect any speckle stuff at all.
it’s really useful for cases like this where you want to pull up the important attributes. I implemented them on each of your classes to display the properties we’re talking about in a condensed way so you don’t need to do any manual traversal and printing to debug this.
hehe yes I noticed this issue in your object model which is why I brought it up! it’s a pretty common mistake in python hehe. I fixed this as well in the previously attached files to avoid this issue
