Changelogs for recent V2 connector updates
I was curious if there’s a Change log that I’m missing for the most recent V2 Connector update updates, Mostly curious about Etabs And if there were any changes in regards to creating stories From revit levels or the bidirectional flow of grids.
You can find a more detailed changelog of our sharp connectors (which includes Revit and ETABS) on GitHub releases page Releases · specklesystems/speckle-sharp · GitHub.
Most of the recent 2.21 updates have been limited to bug fixes, and minor tweaks since our focus is now on the “next gen” v3 connectors.
I’m not aware of any recent changes to Etabs levels/stories. What sorts of changes did you have in mind? I’d be curious to understand your workflow a bit more.
Right now the levels/ stories don’t translate at all between revit and etabs. What we’re working towards is being able to build our model in revit then open our etabs template and receive the geometry, grids, and levels, from revit/speckle . Right now we have to add the levels manually and then receive the grids, geometry
Hey @mdsweeney,
I’ll jump in on the levels / stories topic. See the related discussion here:
https://speckle.community/t/revit-speckle-etabs-mappings-and-levels-and-grids/5430/16
We’re keeping this in mind for the Next-Gen connectors , however, if you’re using the v2 ETABS connector, you will need to preconfigure the storey information before receiving.
We’ve done this for a number of reasons to ensure a reliable receive and avoid some nasty limitations with the ETABS API. :partying_spockle:
Let me know if we can help on anything else for your Revit - ETABS workflows.
Thanks @bjoern - I’d read that one, but saw a couple updates recently so I was curious if there’d been any movement on it. Thanks for the heads up.
