Categories are not imported correctly in Power BI
Hello!
I have problems viewing the categories in Power BI, all the elements in Power BI appear with the category “parts”, however, when exporting from Revit to Speckle you can see that on the web it was exported correctly.
And to make sure that no elements with the parts category were exported, I made the display configuration in Revit and also filtered the categories for export to speckle from the plugin
The error is when viewing the data in Power BI, although the viewer in Power BI shows the elements that are displayed on the Speckle website, the category data only shows pieces
I am also sharing the link with you in case you want to help me by viewing the data directly. Thank you very much in advance.
https://app.speckle.systems/projects/38afb7cd58/models/75d28fedf0
Hey @juan_jose_villegas,
What version of the connector are you using? I use the latest 2.20.1 and i see all the categories.
Here is the categories in PBI:
Make sure to click LOAD MORE to load all the categories.
This was the solution, thank you very much
