Ray_Harli
(Ray Harli)
January 11, 2023, 1:30pm
#1
I have managed to successfully install the desktop manager for windows but when I try search for any connectors I just keep getting the response: no connectors found??
I have disabled all firewalls and anti-virus software but keep getting the same error.
Please help
gokermu
(Mucahit Bilal GOKER)
January 11, 2023, 2:07pm
#2
Hey @Ray_Harli ,
Sorry to hear that. To understand the issue better:
What is your OS?
Are you using a personal or work network?
Can you take a look at the Log ?
You can find it under Settings > Show Log. There should be a .txt file.
teocomi
(Matteo Cominetti)
January 11, 2023, 3:12pm
#3
In addition to what Bilal said, it could be that a VPN is messing around or a group policy on you pc.
Can you access these URLs?
Here is more information that you can pass to an IT department: FAQs | Speckle Docs
Ray_Harli
(Ray Harli)
January 11, 2023, 6:46pm
#4
Hi @gokermu and @teocomi thanks for helping tackle this.
I am using windows 10
I get the same error on both a work and a home computer. I have tried it on several different computers some of which are not connected to any LAN.
I have disabled all firewalls and anti-virus checkers
I am not using a VPN
I can access both https://releases.speckle.dev/ AND https://releases.speckle.dev/ through a web browser without any issues
Here are the last few lines of the log file, I have attached the full file if you need it:
SpeckleManagerLog20230111.txt (3.5 KB)
2023-01-11 20:22:30.075 +02:00 [INF] Checking for updates…
2023-01-11 20:22:30.879 +02:00 [INF] Update status:UpdateNotAvailable
2023-01-11 20:22:30.879 +02:00 [INF] Refreshing accounts…
2023-01-11 20:22:30.880 +02:00 [INF] Getting accounts
2023-01-11 20:22:30.885 +02:00 [INF] Got accounts
2023-01-11 20:22:30.885 +02:00 [INF] Accounts count: 0
2023-01-11 20:22:30.885 +02:00 [INF] Refreshing connectors…
2023-01-11 20:22:32.614 +02:00 [ERR] Could not reach the Speckle servers
Any further thoughts?
gokermu
January 12, 2023, 4:51am
#5
Do you have any accounts under Accounts tab?
Ray_Harli
(Ray Harli)
January 12, 2023, 10:43am
#6
Yes I have two different accounts that are showing up.
teocomi
(Matteo Cominetti)
January 12, 2023, 10:54am
#7
Hey Ray,
This is really weird, the only thing I can think of are some changes to how we deal with proxy settings.
Did Manager ever work for you in the past or is this the first time?
Could you please try with this older version?
https://releases.speckle.dev/manager2/installer/manager-2.7.4-beta.exe
NOTE that as it launches for the first time it’s try to auto update to the latest version and so you should click “Cancel update”:
Ray_Harli
(Ray Harli)
January 16, 2023, 10:13pm
#8
Hey @teocomi
That older version worked!!
This is my first time using manager…
teocomi
(Matteo Cominetti)
January 17, 2023, 9:07am
#9
Thanks for checking @Ray_Harli !
So, is it correct to assume that you have some sort of proxy running on your computer?
Ray_Harli
(Ray Harli)
January 18, 2023, 7:29pm
#10
No proxies at all running on any of my pcs…
chuongmep
(Chuong Ho)
January 19, 2023, 1:31am
#11
Same problem with version recenly
gokermu
January 19, 2023, 8:01am
#12
hey @chuongmep ,
are you still experiencing this issue? i had it this morning but refreshing seems to fix it on my end.
chuongmep
(Chuong Ho)
January 19, 2023, 8:05am
#13
confirm , It working now in my side.
teocomi
(Matteo Cominetti)
January 24, 2023, 11:55am
#14
Hey Ray,
Thanks for helping us debug We’ve made a new release (2.8.3) while it might not solve your issue, it should help us better understand what’s going on.
Could you please install it and send us the log?
Here’s a direct link or you can update in-app as well: https://releases.speckle.dev/manager2/installer/manager-2.8.3.exe
This version should also fix some of the connection glitches you @chuongmep were experiencing
