I am new to Grasshopper and to Speckle as well. I want to work with some IFC models which were generated in Tekla Structure. I want to get the attributes of the elements.
I tried to receive the data through a stream. My first problem is that I can not select the particular model to work with. In my account, there are several models and I want to choose between them.
I got everything from all of the models but I can not get the attribute values to them.
The data should be there cause I can see it in my speckle account.
How could I work with the elements and attributes?
My issue is that I can not get the parameters which are attached to the elements.
I thought that I need to deconstruct the model multiple times to get until the neccessary level but it did not worked for me.
I was not clear. Online, in Speckle it works, and I can see everything.
I need all the data in Grasshopper. I tried all nodes to combine but I could not figure out how counld I work with the data that I can see online within Grashopper. I need to get eg. sizes or weight.
This method works really good. Thank you for sharing it with me.
I have only one issue with it, I can get everything out that is under properties but I can not get the base information about the element. eg. id, name, ifcType, description
