I’m trying to stream a bunch of walls from Revit, but I keep on getting the Warning as below:
An item with the same key has already been added.
- at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)*
- at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)*
- at Objects.Converter.Revit.ConverterRevit.<>c__DisplayClass3_0.b__1(KeyValuePair`2 x)*
- at System.Collections.Generic.List
1.ForEach(Action
1 action)* - at Objects.Converter.Revit.ConverterRevit.GetAllRevitParamsAndIds(Base speckleElement, Element revitElement, List`1 exclusions)*
- at Objects.Converter.Revit.ConverterRevit.WallToSpeckle(Wall revitWall)*
- at Objects.Converter.Revit.ConverterRevit.ConvertToSpeckle(Object object)*
- at Speckle.ConnectorRevit.UI.ConnectorBindingsRevit.d__9.MoveNext() in C:\Users\circleci\project\ConnectorRevit\ConnectorRevit\UI\ConnectorBindingsRevit.Send.cs:line 85*
I tried streaming it from two different accounts, restarted Revit etc, but the error is still the same. Any other ideas?
Bests!
Joanna
