C3D system to Revit = Pipe Segments = x
Hi, Im trying to Speckle a certain service system from C3D 2023 into REVIT 2023.
I have tried everything I can, but the pipes keeps coming in as pipe segments…
Please help figuring this out, thank you!
i have the same problem
@clrkng @oguzhan should we say this workflow is not supported anymore?
@Stephan @Juanvega
Sounds like our current C3D pipes → Revit workflow may be buggy, could you:
  • link to a sample speckle version that you’ve sent from C3D with the pipes that are incorrectly receiving, or email me the C3D file at claire[at]speckle.systems
  • send a screenshot of what it looks like in Revit, as pipe segments?
Pending the official release of our next gen connectors, fixing bugs with our current connector is not a priority, but if it’s a simple issue I can potentially make a hotfix.
A heads up that this particular workflow (receiving C3D pipes as Revit pipes) will not be transferred to the next gen connectors for quite some time.
