Hi Matteo
I hope you are doing well and thank you for the great work.
I adress this issue in dimentionning room, the dimension goes betwee 2 room not inside the room.
Can you check on your side.
Thank you.
Hey @Pascal ,
Thanks for reporting this. I think you mean double clicking on the dimension tool results in measuring the exterior of the room.
@alex can you check why this is happening? 16244-dimensioning rooms - Community Reports | Speckle
Let me know if this is a connectors issue.
