Bug when re-showing a sketch in a viewer (dev)
Hi @alex
I’m coming back for our geometry viewer.
I have a bug happening only with sketches (received from TopSolid, no problems with other objects as forms). Using the filtering extension, when I hide, it is ok, but when I show back, i have kind of an infinite loop in the console. Which prevent me to code a button.
Here is a really small example (try activate the showObjects line), let me know if you need me to build it on github.
As it happens only with sketches, I have the feeling the error may come from the three.js handling of lines objects?
import {
  Viewer,
  SpeckleLoader,
  CameraController,
  UrlHelper,
  FilteringExtension,
} from "@speckle/viewer";
async function main() {
  const speckleContainer = document.createElement("div");
  speckleContainer.id = "speckle-container";
  document.body.appendChild(speckleContainer);
  const viewer = new Viewer(speckleContainer);
  await viewer.init();
  const cameraController = viewer.createExtension(CameraController);
  cameraController.toggleCameras();
  const filtering = viewer.createExtension(FilteringExtension);
  const urls = await UrlHelper.getResourceUrls(
    "https://app.speckle.systems/projects/d5b671524f/models/75e4788d3e@58fb90f03e"
  for (const url of urls) {
    const loader = new SpeckleLoader(viewer.getWorldTree(), url, "");
    await viewer.loadObject(loader, true);
  filtering.hideObjects(["7a531d10f5d8389f903582e373976dfc"]);
  //filtering.showObjects(["7a531d10f5d8389f903582e373976dfc"]);
main();
Hi @RaphaelVouilloz
There indeed was a bug with the viewer library that we’ve been seeing happening for a while now, but we couldn’t reproduce. But with your help we finally managed to isolate, reproduce and finally fix it so a big thank you for your help! :partying_spockle:
It’s already up on the repository and we’ll make a viewer library release ASAP.
*Edit: A new version has been published
Cheers
Awesome, thanks @alex
Happy to helped :smiley_spockle: works perfectly now
