Hi there!
Is it possible to send and receive block definitions in ?
I have a use-case in which I would ideally update all existing instances of a definition with a new definition.
Hi there!
Currently block definitions are only sent as a property on any block instances that use the definition, but not separately as just definitions.
Being able to send and update block definitions is a super valid workflow however, so I’ll make a ticket to add support for that in our next sprint
Okidoki thanks Claire! When is your next sprint?
We’ll release 2.14 around mid-May, you can track the issue here
