When using a computer through Remote Desktop, Revit won’t send the objects, but we can print out the view as an NWC and it will push. Does file size cause complications with sending?
Hi @bcall! Several questions:
- it will push nicely from navis?
- can the problem be reproduced in a non-remote desktop environment?
- are you using xyz, or a different self-hosted server?
Lastly, and probably most important, it would be brilliant if we could get our hands on the file in order to reproduce the issue (we won’t share it with anyone)!
It does push nicely from Navis. I will try to reproduce it on a non-remote desktop
we are using xyz
I’ll fill you in with more details as I give it a try
