What’s the best way to list object ids currently in a stream? Or, more specifically, the object ids expected by the speckle viewer’s loadObject()
method?
From a dotnet server, I’ve managed to create an object with some displayValue
geometry, commit it to a stream, and then view it on my locally running server’s frontend. In C#, the class is defined as:
public class TestModel : Base
[DetachProperty]
public List<Polyline> displayValue { get; private set; }
public Box bbox { get; private set; }
public int random { get; private set; }
After a commit with Helpers.Send()
, if I use the Helpers.Receive("{streamDomain}/streams/{streamId}/branches/main")
method, I get the following:
"totalChildrenCount": 0,
"applicationId": null,
"speckle_type": "Base",
"displayValue": [
"value": [
0.0,
0.0,
0.0,
1.0,
2.0,
3.0
"closed": false,
"domain": null,
"bbox": null,
"area": 0.0,
"length": 0.0,
"units": "m",
"speckle_type": "Objects.Geometry.Polyline",
"id": "cff3f3652f1b01c06a600974b84ed354"
"bbox": null,
"random": 1450717906,
"id": "8352492e5ae6083d3d33453d9de336da"
These results are more or less expected. Please do not judge my line quality. He’s doing his best.
The problem I’m facing is, if I use either one of those listed ids (the top-level object or its displayValue
) with the javascript viewer.loadObject(
${streamDomain}/streams/${streamId}/objects/${objectId})
method, it says it can’t find an object with that id. The id changes if the object changes, which is understandable, but I can’t get any ids from Helpers.Receive()
to work.
If I visit the server frontend, the data view will present me with almost the same values as Helpers.Receive()
Importantly, the id
from this latest commit is different from the value in Helpers.Receive()
. If I use this id in viewer.loadObject()
, everything works as expected.
What I’d like to do is commit a change and then have a way to (re)load that model after the change has completed. Is there a way to programmatically find the same id being presented to me in the viewer?
