Hello everyone,
I am starting my first attempt at Speckle Automate for the Hackathon and I have run into early trouble creating an initial function to then develop my code within.
I followed the guide Creating Functions Guide with the Python template. The only changes I made to the template were a couple of spelling updates in main.py (just to test making an initial commit through Codespace) and I created an initial v0.1 release so that it appears in the Speckle Functions and I can assign to a test model.
Any time I trigger (on bot the test model and others) it I get the error below referring to the speckle_automate library and no pytest module. As this is outside of the code repo I assume it’s not a problem I can solve in the repo itself? I haven’t worked with containerization before. Any help appreciated.
Thanks,
Thomas
[prepare] 2024/06/07 15:39:56 Entrypoint initialization[22a3f82886-4bbdec246a-1b705e] Traceback (most recent call last):[22a3f82886-4bbdec246a-1b705e] File “/home/speckle/main.py”, line 7, in [22a3f82886-4bbdec246a-1b705e] from speckle_automate import ([22a3f82886-4bbdec246a-1b705e] File “/usr/local/lib/python3.11/site-packages/speckle_automate/init.py”, line 2, in [22a3f82886-4bbdec246a-1b705e] from speckle_automate import fixtures[22a3f82886-4bbdec246a-1b705e] File “/usr/local/lib/python3.11/site-packages/speckle_automate/fixtures.py”, line 5, in [22a3f82886-4bbdec246a-1b705e] import pytest[22a3f82886-4bbdec246a-1b705e] ModuleNotFoundError: No module named ‘pytest’
