markcichy
(Mark Cichy)
11 August 2021 15:06
1
Hello @cristi / @dimitrie ~
This is likely a question for @cristi - because it involves the docker-compose.yml config.
Can you add/setup sendgrid
or mailgun
support to the yml file as you used to be able to define in .env
with Speckle 1.0?
OR, better yet, how does one ref a .env
file from within the yml file?
Lastly, do you have a template .env
file to work with? What is the syntax of this file if many of the params identified there may already be covered in the yml
file?
cristi
(Cristian Balas)
11 August 2021 22:01
2
@markcichy
If you use the docker-compose yml file, you don’t need an .env
file. You can specify the environment variables right in the yml file.
For configuring email, you can add the following env variables directly to your docker-compose yaml file:
EMAIL: "true"
EMAIL_HOST: "<smtp_host>"
EMAIL_PORT: "<smtp_port>"
EMAIL_USERNAME: "<smtp_username>"
EMAIL_PASSWORD: "<smtp_password>"
EMAIL_FROM: "speckle@your-domain.com"
You can get the values smtp_*
from your email provider, and the EMAIL_FROM
is what source email address to use when sending email on behalf of the speckle server (you must have access to send from that domain in your email provider)
PS: It’s important to include double quotes for "true"
and "port"
. Otherwise the yaml specification will transform them in boolean / integer, but environment variables must be strings.
markcichy
(Mark Cichy)
22 September 2021 16:17
3
Hi @cristi ~
Receiving this error:
ERROR: In file './docker-compose.yml', service 'EMAIL' must be a mapping not a string.
Lines in docker-compose.yml
file are as follows:
EMAIL: "true"
EMAIL_HOST: "smpt.sendgrid.net"
EMAIL_PORT: "587"
EMAIL_USERNAME: "usr**"
EMAIL_PASSWORD: "pwd**"
EMAIL_FROM: "speckle@mobiusnode.io"
markcichy
(Mark Cichy)
22 September 2021 16:27
4
Just noticed a spelling error in the domain, regardless, the issue persists…
cristi
(Cristian Balas)
22 September 2021 16:44
5
Hi @markcichy ,
Hmm, EMAIL
should be an environment variable, not a service.
The yaml format is very sensitive to indentation. Are you using the correct indentation for those env variables?
If not sure, can u paste the full yaml file? (Replacing just the sensitive values)
markcichy
(Mark Cichy)
22 September 2021 16:56
6
They are double spaced like other elements defined within.
markcichy
(Mark Cichy)
22 September 2021 17:01
7
version: "3"
services:
# Speckle Server dependencies
postgres:
image: "postgres:13.1-alpine"
restart: always
environment:
POSTGRES_DB: speckle
POSTGRES_USER: **concealed**
POSTGRES_PASSWORD: **concealed**
volumes:
ports:
- "127.0.0.1:5432:5432"
redis:
image: "redis:6.0-alpine"
restart: always
volumes:
- ./redis-data:/data
ports:
- "127.0.0.1:6379:6379"
# Speckle Server
speckle-frontend:
image: speckle/speckle-frontend:latest
restart: always
ports:
- "0.0.0.0:80:80"
speckle-server:
image: speckle/speckle-server:latest
restart: always
command: ["bash", "-c", "/wait && node bin/www"]
environment:
CANONICAL_URL: "https://speckletwo.mobiusnode.io"
SESSION_SECRET: "**concealed**"
STRATEGY_LOCAL: "true"
DEBUG: "speckle:*"
POSTGRES_URL: "postgres"
POSTGRES_USER: "**concealed**"
POSTGRES_PASSWORD: "**concealed**"
POSTGRES_DB: "speckle"
REDIS_URL: "redis://redis"
WAIT_HOSTS: postgres:5432, redis:6379
# EMAIL: "true"
# EMAIL_HOST: "smtp.sendgrid.net"
# EMAIL_PORT: "587"
# EMAIL_USERNAME: "**concealed**"
# EMAIL_PASSWORD: "**concealed**"
# EMAIL_FROM: "speckle@mobiusnode.io"
# preview-service:
# image: speckle/speckle-preview-service:2
# restart: always
# mem_limit: "1000m"
# memswap_limit: "1000m"
# command: ["bash", "-c", "/wait && node bin/www"]
# environment:
# DEBUG: "preview-service:*"
# PG_CONNECTION_STRING: "postgres://speckle:speckle@postgres/speckle"
# WAIT_HOSTS: postgres:5432
cristi
(Cristian Balas)
22 September 2021 17:04
8
Oh, they must be indented like the other environment variables above (6 spaces, if i’m not mistaken)
