I’m relatively new to the Speckle world. So far Im super intrigued with what it can achieve.
I’m wondering if Speckle is able to assign colour properties to lines/curves received from Grasshopper?
I imported a bunch of lines with their corresponding network analysis colour properties. For some reason, it wouldn’t display the colour on the web viewer.
Hi @Siddharth12, it’s not you - it’s us! We’ve heavily optimised things in the viewer for solid “things” but we didn’t have time to roll the same things out for line-based objects.
One (inefficient) solution would be to pipe those curves out (maybe with some easier-on-the-vertex-count-method that does not use circles), and set properties to those extrusions - then things will be able to get nicely coloured.
I work heavily with large-scale networks and piping each segment would probably render in crashing. See attached ex of a small file I was able to put on Speckle. It’ll be great if I could also see the network analysis colours to further my cause of web visualization.
As a PS, if you’re willing, we’d be happy to give it a go to “pipe” some of those lines if you’ll share a simplified model/defintion with us. Right now, solids are displayed 1000x more efficiently in our viewer than line-based geometry, so i’m actually almost sure it would work
Hi @dimitrie Thank you for opening up the issue. Look forward to it being rolled out soon.
In the meantime, I tried piping the curves to mesh for an example network. Works, but unfortunately the colour scheme changes from Grasshopper to Speckle. Is that an internal issue? See attached…
Speckle colours
Hi Sid! no worries, looks nice! No worries about the pedantism - it’s legit.
We default to the trendy pink-blue gradient in the frontend, but actually it can be customised We didn’t add this yet in the frontend, as it would’ve been quite a bit of extra legwork with allowing people to choose colours, etc.
Nevertheless, this is relevant when you want to colour things by arbitrary numeric props - which seems the case from your screenshot.
We’ve got a tutorial on how to set specific materials to objects from gh:
The property on the speckle object should be named renderMaterial instead of material, and then it will be picked up automatically and used.
The last step that you did is not needed. It is another feature that colors objects in the scene dynamically at viewing time based on any property. (in this case, it colored based on the numeric property material.diffuse, which is the int32 representation of a color - it was not decoded as a color and it just mapped the values on a gradient)
